Sure is. The feel and street manners are point on, but as I mentioned before, I will have to see in the Fall how it's doing ET and MPH with some fine T&T at the track before the season ends. I usually try and run in the cooler weather. The Silverdome runs in Detroit were clean and the car was pulling with some good steam the likes I have not seen before, but it was just shy of an 8th mile though with less shut down area, so who knows. In short, the car is idling way better and super sharp on the go pedal. I did install it using aluminum studs, lock washers and nuts on all four corners of the plenum.LOL.
