I would run a relay with a Halogen bulb that way you can get full battery power. You can pull battery power from the starter relay or alternator. On top of that you will not pull high power through your light switch. Headlight relays are small and plastic case and should be a ounce or 2. Hey I like bright lights.
And it's easy to wire up.
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS 68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam 65 Chrysler 300 Convert. project 57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son 2003 Dodge Dakota R/T "DEAD"
