I've been through Potomac quite a few times...
Maybe next time I'm down in Hamilton, I can stop by and see your project. The pics look great.
The ammount of airborne material from rolling or brushing has got to be just about zero. As far as I'm concered, the precautions I took are overkill. But, it is of course up to the individual painter to do what you're comfortable with.
Interlux Paint (maker of Brightside) has a video of a guy painting their two-part "Perfection" paint with a simple paper dust mask:
http://links.streamingwizard.com/yachtpaint/9-04/WMV/perfection-usa4-bb-wmv.asx
And another video with NO protection: http://links.streamingwizard.com/yachtpaint/11-06/US_Perfection-3-paint.asx
Here is the MSDS for Interlux Perfection: http://www.yachtpaint.com/msds_pdf/YGB001_usa_ENG_E1.pdf
It contains "hexamethylene di-isocyanates." I looked up the info on that chemical and found this: http://www.atsdr.cdc.gov/tfacts120.html
Apparently it doesn't evaporate well into the air.
I also found the MSDS for the Van Sickle enamel hardener: http://www.vansicklepaint.com/7019X.PDF
The number one ingredient by weight is the Isocyanate. They don't say exactly what kind of isocyanates they are using ... it's listed as a "trade secret." But ... they do give its vapor pressure as 5.2 mm Hg, which is much lower than atmospheric pressure. That means it's not likely to evaporate into the atmosphere.
I also called the local OSHA office, and they said that the primary danger of isocyanates is in spraying -- breathing the fine droplets. They recommended good ventilation and wearing a respirator.
So ... I'm thinking maybe you are right about this. Perhaps the primary danger for isocyanates is for spraying. Rolling should be fine IF YOU USE A PROPER ORGANIC VAPOR RESPIRATOR. Make sure the respirator fits tightly around your mouth and nose. If you have a beard, that creates special problems. Some old pro painters use vaseline to help seal around the edges of the respirator. Also, using goggles and gloves is a good idea. That's what I intend to do anyway.
Man...looking at that MSDS, that stuff is pretty toxic. I can't believe they apply it without some sort of protection...talk about a lawsuit waiting to happen!
After the results I've had with the hardener, I'm convinced it's the way to make this process work. When I do have more time (whenever that is) I'm going to do some more work with it. I've got another spare fender (the other one off the truck) and I'm going to try and paint a bigger area and see what happens. Safety shouldn't be an issue, as long as (like you said) you wear the proper respirator.
And yea, let me know when you'll be in town. My schedule is...pretty busy, but I can see if I'll be around.
