If you guys are going through the hassle of spraying... why not just spray using the proper automotive paints like Charger suggested. Doesn't make sense to go through all the trouble to spray and then use the "wrong" paint. Sure it may be cheaper.. but spend an extra few bucks to get the real stuff. If I had a compressor and gun on hand I would definetely be spray the car instead of rolling brighside...
