I've been following this for a while and am finally willing to take the plunge! I have a Chevy truck (I know... Mopar forum) with the peeling paint syndrome due to the galvanized body. I was re-reading some posts when I found that the oil-based paints are not compatible with galvanized steel!
The rustoleum site recommends painter's touch (water based). Anyone tried this and had luck? Anyone paint galvanized? Any help is greatly appreciated!!! I want a one-color truck again!
When I was at Ace the other day I saw that Rustoleum makes a special primer specifically for Galvanized Metal. Maybe if you covered your bare metal areas with this primer first you would have no problem with regular Rustoleum, guess you'd have to research this first though. Just figured I'd throw in my
