Hurray for an update Exit! lol.
About the bubbles you are experiencing, do you forsee that as a problem on the final coat? When you wetsand the bubbles (if you get them on the final coat) won't it leave pin holes in the paint?
Actually this WAS supposed to be the final coat, but I realize I need a bit more practice which is why I stopped short of doing the doors and fenders last night. I will just have to lay it on then roll over it a few times until all the bubbles are gone or yes it probably will leave pinholes.
