Would these paint jobs be considered 10 footers or are they equivalent to any good solid-colored (I'm thinking white) high-gloss paint job say, under shopping center lights at the evening cruise-in ?
I am only about half done with my car, I have my front fenders done except for the final wet sanding and polishing, and it has less orange peel the way it is now than my 97 Blazer. My car is a white and even with only 4 coats on it, it needs to be out in BRIGHT sunlight to see any issues, and these will come out with the next sanding or 2. As long as you use a sanding block while wet sanding you can smooth out ALOT of imperfections with the number of coats that are put on. I would say that with the flaws that I have right now you have to get within 5 feet to see them.
Gerbs
