Thanks for all the help in hunting down this stuff! I thank you very much. I found a place near Downtown Toronto where I work and will be checking it out. Here's the address for those of you interested in a Downtown Toronto Location:
http://www.gencomarine.com/store/groupdetail.cfm?CatID=6&SubCatID=74&ProdID=0&GroupID=95
I have a question regarding the Brightside painting method. It seems that its hard to lay down with a roller without any orange peel or waves. Do you suggest cutting the Brightside more with mineral spirits to get a more even texture/layer? I've read the wikki outlining the steps on how to paint the car:
http://carpainting.wetpaint.com/page/Rollering+Interlux+Brightside+Polyurethane+Paint
I noticed you cut it with 5-10% of #333. Do you believe cutting it more would work better in terms of getting a more smooth texture?
Thanks.
