Charger....
("besides, a good home auto paintjob using auto paints needs wetsanded/buffed/polished anyways, so it's really not that different. also the inbetween coats wetsanding is not done as good as the last wetsand before polish, it's just a quick wetsand of the whole car to cut down peel, that's all, it does'nt have to be perfect, it's the last wetsand that does.")
Are you saying the roller job doesn't need a real good wet sand just a quick- one between every other coat to cut down on orange peel???
I've definitely noticed it makes preceeding coats come out much smoother with less and less pronouced orange peel and more gloss. But, I might be spending much more time sanding between coats trying to eliminate all traces of orange peel when it isn't necessary.....and risking cutting into the underlying layers
