Quote: If I may ask, if the trim rings are on it, then shouldn't the valve stem extensions also be on it.
Also , if the rings were installed ( aka - dealer prepped ) then also shouldn't the additional trunk items be installed
There you go Bill!!! The perfect opportunity to go in next year with your entry and knock us aside! I suspect however that you might be one of those individuals who posses this infinite wisdom and knowledge that never seems to make it into the reality of a restoration. In fact, most of it is wasted in mere words or typed skepticism on the forums. Just out of curiosity, were you able to re-evaluate the incorrect statement you made (earlier in this thread) about A/C upper radiator hoses and their applications?
