Quote: Do you see the confusion that is starting to developed here? Chryslers own parts application book seems to be contradicting what came on their own cars. How can anyone be absolutely sure what is correct unless you were lucky enough to still have the original hose when you took possession of your car?
I believe it has more to do with the print date of the parts information than a contradiction by Chrysler. I know for sometime the part number for the connecting rods for the '69(1/2) A12 440 was listed as the so called heavy duty "Six Pack Rods" but that's only because the information was printed and revised after the spring of '69 production. The '69 built A12 440's did not have "Six Pack Rods" and did have single bolt cams, plastic cam gear...... The steel H-wheel part number changed from what was on the production "addition and deletion list" and several other parts were superceded by improved or current available items by the '70 and '71 revised parts information.
