Quote: I have personally seen this car through the whole process. You will have to trust me - the bottom is right-on. The flash / camera makes it look brighter/whiter than it is. If you look at the before picture Dave posted of the bottom you will see the same amount of over-spray... just the "fresh" version is easier to see the white. Dave
I believe you 100% Dave,I just couldnt see a dominate overspay line in the "fresh" version picture like you see on the originals,I still believe there is still something wrong with color of the primer,even with the light or flash of a camera the primer should appear to be a little more duller or darker.Im not going to say its wrong though,pictures can lie,but the rest of the car looks awesome according to the pics
