Quote: Dave did you blackout your cowl? If so, could you provide a pic or two? Sorry if you have already and I missed it.
What was your rational for not putting the Shrader caps on the tires and instead leaving them in the trunk? Was it because they were delivered that way from Chrysler. Thanks.
The ones on the stems are the ones that would have been switched at the dealership when it was prepped.
Switched to the Schrader extension caps?
Yes!
Thanks and thanks in advance if you are able to post a pic of your car's cowl. I have a few sets of those but was confused as to whether I should leave them in the trunk or put them on the tires.
