Quote: Here are the caps that were delivered in the trunk. I will take a close up of the "regular" valve stem caps that came with the car from the assembly line.
Dave, I know this is a silly question, but... is this the correct packaging for these valve stem extensions? The reason why I ask is that I have some originals that are in a small envelope that has the typical Chrysler parts white and blue colors, and I have some NOS ones from recently, that are in the clear packaging as you show.
Thanks, Dan
Hi Dan, I wouldn't even begin to try and figure or comment on the various vendors that supplied these pieces to Chrysler. The set I have for my Cuda were in a small brown paper envelope with the part number. All I can tell you is that the ones I have (in the clear plastic packages) list the early part numbers so they are not a later style or revised version. A good rule of thumb is the earlier the part number, the older the issue of the part!
