Scott my Man! I wasn't referring to you as the "Nuh Uh!" people out there. It is always a pleasure hearing from you and your input to these things. More than anything I was worried about the cloth and am positive that it is the correct original material. Same for the headliner. I thought I was absolutely clear as to what I wanted these guys to find but I will double check. (Thanks for the heads up.) You would not believe the trouble I went through to get the interior finished in this car. Even the welting cord was the different type that was originally installed between the material panels. They were never were an exact match (which is what you get with all the new repro interiors) from the factory!
