Quote: Dave Your suspension looks great, I do have a question though on your magnum rims. Were you able to locate the original assembly line / early center caps or did you have to use to second design center caps?
That was one of the easiest in the scheme of things. Most know that E Body magnums came with the 2" high center caps. The second run that everyone is selling as NOS are the 2 1/4" style. I simply had the originals re chromed so it made it an easy solution.
This wasn't a trick question was it Mr. B? It was too easy compared to other aspects we researched on this car.
