Tonight, I finished wiring up the tach, speedo, fuel level, voltmeter, oil pressure, and water temp gauges. All gauges are plugged into Weatherpack connectors. I still have the turn signal and high beam lamps, and trans temp gauge left to get done.
Gone to the dark side with an LS3 powered '57 Chevy 210
