Quote: Glad to hear all is well. Every bit of progress gets oyu a little closer. I'm in the middle of a winch install picked up a new used 8274 off e-bay last week. I'm putting power at both ends with Anderson quick connectors, if you have given it any thoughts run the cables while you are looking at the frame, easy to drill anchor holes.
Looking forward to the engine post.
Pardon my ignorance, but why would I need or want power at both ends for the winch?
Gone to the dark side with an LS3 powered '57 Chevy 210
