I purchased the trans to transfer case gasket. If I have time this weekend, I'll drop the t-case and install it.
Meanwhile, I've been forging ahead with the stereo system install. I mounted the amplifiers to the floor, which required fabbing up some mounting brackets. I also made a mounting bracket for the front passenger side speaker. I plan to make the mounting bracket for the driver side front speaker tomorrow.
I built speaker boxes for the rear 6x9's. They will be sprayed with black Monstaliner this week. The front enclosures will also get the Monsta treatment.
The new hydroboost unit showed up yesterday.
Gone to the dark side with an LS3 powered '57 Chevy 210
