This morning, I got started on the rear fender flares. I want to make the panels out of thick steel, but at the same time, I have to be able to bend it by hand, so that will limit me to 16 ga. steel sheet metal. I've decided I'm going to spray them with black Monstaliner, same as the bumpers and rock sliders.
These are the weld-on tabs I'm going to use, to enable bolting the flares to the tub.
Gone to the dark side with an LS3 powered '57 Chevy 210
