Wiring update. I wired in the trans temp gauge, trans cooler fan, and the high beam and turn signal indicator lamps.
Electrical work left to do:
- Run various ground wires to the frame - Run battery cables - Wire up the horn relay - Install the steering column (temporarily, for circuit testing)
I'm on track to check the circuits next weekend. The dash panel will not be installed during testing. I'll use my battery charger in place of the battery, set at a 10 amp output.
Once everything electrical is shown to be working properly, then I will install the stereo system.
Gone to the dark side with an LS3 powered '57 Chevy 210
