Body and frame are once again reunited, for good!!
I taped off and scuffed up the red painted areas underneath the rear fender flares, in preparation for black Monstaliner.
I'm glad I decided to stick with the gray for the exhaust.
Don't mind the flash rust on the axle, that was when I pressure washed everything. The 14 bolt will need to come out one last time to do the finish welding and painting.
Gone to the dark side with an LS3 powered '57 Chevy 210
