Tonight, I got the trans cable shifter hooked up to the trans. It's cable-shift mania in my garage!!! :rofl:
Some random pics of the install. The Winters Sidewinder shifter cable cleared everything beautifully. When I first opened the box and looked at the bag of linkage parts that it came with, I was thinking, what the hell kind of Rube Goldberg setup is this?? But actually, its quite a clever design.
The long gold-ish brackets were originally aimed straight back. I removed the bolts and clocked the brackets downward, to help point the cable in the direction it needed to go. Otherwise, the cable may have come up too short. The electrical tape around the cable hole in the floor is temporary. I will eventually put a rubber grommet there.
Gone to the dark side with an LS3 powered '57 Chevy 210
