Quote: the drag-link appears to be hitting the front spring segment...?????
Looks Killer
Rickster
Thanks, Rick. There is actually a good 3/8" of clearance between the top of the leafs and the bottom of my makeshift tie rod. When the frame and suspension sees the full weight of the body, drivetrain, etc., the leafs will flatten, and that clearance will increase.
Gone to the dark side with an LS3 powered '57 Chevy 210
