Quote: Thanks guys, but I'm really just a hack welder. I need to work on making consistently nice welds. I recently switched to .025 wire, and that has made a big improvement in the quality of my welds. Lots of practice has helped, too. scratchnfotraction, no, I bought the ladder bar brackets. I was going to make my own, but when I saw that Applied Racing (ART), which is close to where I work, sells them for less than $10.00 a piece, I didn't see any benefit to making them. And, just in case someone got the wrong idea, I bought the shock hoops, too. If I had access to a bender, I would have made them. I picked up the final bits of hardware to make my anti-axle-windup ladder bar. The round thing is a flex joint, also known as a Johnny Joint. It will be welded to the front of the ladder bar.
JMO but .025 is to small for frame work and such I was told by a cert. welder when I started my cage not to use any thing smaller than .030 and he would have preferred .035.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
