Quote: they probably based that on the relatively light weight with the expected torque. what does a jeep weight? a larger convertor like a 10 1/2 or 11" would probably be around 2000-2200 rpm stall.
Well, my Jeep originally weighed right around 3,000 lbs. But, I've added frame crossmembers, heavier axles and much heavier tires, plus a heavier engine and a full rollcage is in the plan, so, I'm guessing the final weight to be around 3,600 lbs. That's the weight I gave to the PTC sales guy.
Gone to the dark side with an LS3 powered '57 Chevy 210
