DATELINE TAMPA: A MILESTONE HAS BEEN REACHED AT JEEPER DAVE TRAILSPORTS, A WHOLLY OWNED SUBSIDIARY OF DUSTERDAVE MOTORSPORTS..... BODY WORK HAS OFFICIALLY BEGUN!!! I spent a good part of today doing the body work on the front of the grille. As you can see, it needed a lot of attention to get it straight. Since I sanded down to bare metal on some spots, tomorrow I'm going to spray a single coat of epoxy primer, followed by several coats of high build. A final sanding with 320 grit, and this piece will be ready for paint.
New tubular fender flares mounted, waiting for their coat of black Monstaliner.
Gone to the dark side with an LS3 powered '57 Chevy 210
