Some notes that I have run across: 12.5-13.5 cold startup and as the motor warms up, it should "lean out" to your idle A/F reading. If you start it up cold, leaner than your normal idle A/F, then it will be a bear to keep running during warm up.
Are you running an auto or a manual tranny?
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
