Is this A/F dip showing when the main jetting is starting in or is there something else? It seems weird that it takes almost a 1.0 dip in between the 3300rpm and 4000rpm range. If this is the main jet, should I lean out the main jets by one or two sizes and restest?
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
