INTERESTING read guyz...... It is my intent to join the 02 crowd when I get motorhome project on-the-road. A couple of Q's .....
How many choices are there for a wide-band 02 combo-kit? Anyone tried to add water-injection to enable going HIGHER UP on the A/F numbers? I knew a guy who worked at Ford who said that either Ford or Mazda tried WI ...and were able to get the A/F #'s out to 25 to 1. IIRC ... but if you ran the car out of water ... the motor was toast.
What are your combo's ....stock type or mild HP?
