Y07_A66 Do you have any results from trying your staggered jetting? I'm curious and have been following your thread for quite some time. I have about the same set up except my carb is a SS750 quick fuel stock jetting it came with 74 primaries and 80 secondaries and I also am using the same gauge as you but I have my sensor mounted in the Y part of my exhaust. I'm curious what your reading is at a steady cruising speed down the highway around 65 to 70 miles an hour. I'm running right now at about 13.5 to 13.8 and at idle my reading is 13.9 to 14.2. My jetting is set at 69 primary and 76 secondary. Keep up the great updates. Thanks Pat Faley 67 Notch back Barracuda 408 stroker 4-speed Peoria IL
