So what did we ultimately find as the ideal numbers?
I am running my Charger tomorrow for the first time in about a year on a 100 miles round trip. I was gonna jot down the numbers as I went through my stages. It's gonna be fun playing with the numbers because this time around, there are two Carb's instead of one.
I should aim for 14.7 and work my way from there but my current setup is:
~440 Dual Edelbrocks (500cfm each) set up in progressive formation, 10:1 compression. ~727 with GVO, 28" tall tire, 3.55s. At 80mph I am cruising at 2200rpm. ~480/280 Isky megaCam ~Recently installed Edelbrock RPM Heads ~HP manifolds (swapping out to shorty Hedman's in a few weeks ~26" Radiator, 4 core. 7-Blade fan with clutch ~I run 95 octane (Thats the standard here)
I have an Autometer O2 Wideband that I just rigged into a Pelican case and an cigarette lighter plug so it can move from car to car.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
