I plan on buying each larger IFR from 037 to 040. That should cover me. I'm only planning on swapping the primary IFR since the goal is to improve the off-idle and low RPM mixture. Did you ever try just changing the primary IFR? To me, it seems the secondary IFR really shouldn't be delivering incremental fuel in the 1K-2K RPM range but I could be wrong.
