Any chance of trying out the TF hyd roller cam? It's smaller than you have been using, but I curious as to how much power it really can make.
I don't think I'm up for testing that cam. It is 20 degrees smaller than what I'm currently running so I think it would kill off a ton of power. Probably be a smooth running tire frying monster in a street car though.
No problem, They claim 620 HP with the TF heads and that cam on a 10.5:1 440.
I believe their 620 HP claim. I bet that cam in my 470 would also make about 620 hp. I'm making 685 hp with a solid roller that is 20 degrees larger as well as a Dominator carb. If I used their cam, intake and carb I'd probably be fairly close to 620 hp also.
