Originally Posted By BradH
Originally Posted By Skeptic
Summit has them listed with steel or Ti retainers.
Info I found from "way back" says there are four different spring & retainer combinations, so the purchaser needs to determine which spring option fits their application:
TFS-61617801-C00 1.460″ dual valve springs
TFS-61617802-C00 1.550″ dual valve springs
TFS-6161T783-C00 1.550″ dual valve springs w/ ti retainers
TFS-6161T784-C00 1.560″ dual valve springs w/ ti retainers
I know the 1.560" is intended for a solid roller up to .700" lift, but don't know what the others are spec'd for.
I'm close to ordering and have spoken to both Summit and Trick Flow Tech Lines. Both came back with same selection recommendations based on current engine build, valve train, and intended use provided. Give them a call as they were glad to be of help in making the right choice.
....and thanks for all the advice in the post up up
B Dartman's 71 Dart Swinger in Mopar Muscle (Sold Dec 2021): https://www.hotrod.com/articles/1971-dodge-dart-destiny-determination/
B Dartman's 71 Dart Swinger in Dodge Garage (Sold Dec 2021): https://www.dodgegarage.com/news/article/showcase/2019/04/destiny-determination.html
B Dartman's 71 Dart Swinger early build pictures (Sold Dec 2021): https://s165.photobucket.com/user/Billswild440dart/library/
