how much horsepower can be made with these heads ?? I don't see dyno numbers?? thanks Ed
330 cfm will make 650 to 700 hp depending on the rest of the combo. 600 hp should be fairly easy to make with pump gas and street/strip type cam. Trick Flow posted dyno numbers for their test engine.
