I test fitted my RAS rocker arms to the TF heads yesterday. Geometry looks just fine up to about .750 lift and then the rocker arm starts to roll towards the inside edge of the valve. Really doubt very many people are going to run that much lift.
There is enough room between the retainer and the seal to go .800 lift and the installed height is right at 2.00 inches.
