Do the valves contact there, or is that for airflow??
That is to transition the large Trick Flow chamber to the smaller bore by removing the ledge that would shroud the valve. It isn't as good as a larger bore, but it's better than nothing at all.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
