Originally Posted By DrCharles
Originally Posted By Thumperdart
Originally Posted By AndyF
Originally Posted By SILVER67
ANDY, is there any dual plane that would be worthwhile to test on your short block with the TF 240 ?
I don't think so. Only half way decent dual plane for a B engine is the Performer RPM and I wouldn't want to run it on a 700 hp engine. It would kill 100 hp and mess up the mixture for some of the cylinders.
As they do on anything w/compression and hp imo................garbage.......
Depends on your definition of "compression and hp", doesn't it? work If you're running 13:1 and 800+, a Performer RPM likely is not part of the build anyway...
Nothing including damn near stockers I deal w/run a dual plane or even a carb smaller than a 750 dp...............but that`s my world which I happen to like................
72 Dart 470 n/a BB stroker street car `THUMPER`...Check me out on FB Dominic Thumper for videos and lots of carb pics......760-900-3895.....
