Did you try the 1050/4500 on an adapter, on the TF manifold?
The TF intake 1050/4150 combo was 5hp better than the unported M1/4500 combo?
I did try the Dominator on the TF intake using a Wilson adapter and it sucked. Lost 20 hp when compared to the 1050-AN QF carb.
It's easy to sit here on the computer and "spend your money", but I'd love to see that test done with a 1050/4500 on top of an HVH 4500/4150 super sucker adapter.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
