[quote=69 plymouth rnr]This is a great thread but is there anyone who can confirm Trick Flows claims on a 440 build they claim . Or any other trick flow dyno numbers with different combos?? THANKS
Had only one day to dink with these combinations.
Trick Flow 240, .030" over 440, stock stroke, 9.9:1 compression, 850 Mighty Demon, Edelbrock Victor and RPM intakes, Solid roller 238/242 @ .050.
Victor.....
500 lb-ft 3,300-6,100rpm
550 lb-ft 4,500-5,300rpm
562 lb-ft @ 4,800rpm
591 hp @ 5,900rpm
RPM........
500 lb-ft 3,100-5,900rpm
550 lb-ft
What numbers do you think they'd produce on a stock 383 short block??
