Here are some pics of PRW stainless rockers on Trick Flows. The geometry is perfect. If the rocker will fit under the valve cover, it can be "adjusted" to have perfect geometry also, at least on the valve side. The Harlands are not going to be better than any other rocker when just bolted on.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
