Only passing on what they showed while doing other heads. They have nothing to gain no matter the results. If it's considered misinformation I'll gladly remove it.
It isn't misinformation, it is just probably at the high end of the range for test results. Test setups vary and test results vary. Most engine guys understand that numbers vary from bench to bench.
And dyno to dyno... and I've seen first hand some pretty big variation between a couple of dynos.
And DYNO to track. LOL.
Who uses the track as a measurement of performance?!
