fabo also has a thread on these heads and did some flow numbers
Yep.
And, as usual, something in the water in Idaho leads to inflated flow bench numbers when compared to two others that are virtually identicle.
Link me, dude.
I was waiting for the big numbers from "the Idaho bench" to get posted here. Kinda curious they weren't. But numbers higher than everyone else sorta confirms that the bench is
Maybe Jim did a little magical clean up of the factory porting, hence the bigger numbers (at least that is what I'd claim
A guy on the bullet mentioned he got one of the first sets of heads. I advised him to send them to Andy F since they're both in the same state. He said he was sending them to Idaho instead. I warned him about the inflated numbers that come out of that part of the country but he sent them anyway.
LINK --- V
Scroll to post #48http://www.yellowbullet.com/forum/showthread.php?t=1178282&highlight=trick+flow+mopar+heads
