Well these springs are around 700 lbs over the nose which is probably more than what the mfgs check with. My guess is they use a flat tappet type spring for their measurements but I don't really know.
I'd be interested to see what you find with your Hughes rocker arms, especially if they were 1.58 with a checking spring.
