Roadhazard, What is the distance between the runner divider centers on your gaskets?
The main purpose of the measurements I posted was to show how the port locations on the fel pro paper gaskets were not centered with the bolt holes, and that on the Indy gasket and the tin valley cover they were.
Also how the spread between to runner dividers on the gaskets and the heads don't seem to be on the same page.
You'd think that dimension should be constant........ But it definitely isn't.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123
Dealer for Comp Cams/Indy Heads
