Originally Posted By scrapmetal
Im sending back the rocker arms I have and looking for some other ones.This is my first Mopar and its turning into a pain. I was looking at some Hugues 15203.I'm building a mild roller 470 and don't wanna spend 1200.
What rockers do you have now? What is the problem with them? You likely don't need different rockers, and it has nothing to do with snake oil, or what brand of rockers, necessarily. Proper set up is key to any rocker working the way it should. Don't get frustrated with your first Mopar build. Just do your research, and use common sense to separate the gems from the nonsense.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
