We are finally getting the '65 Plymouth to test n' tune next weekend with the 470 low deck/ TF 240 headed beast.
We dynoed the engine back in July with an Indy intake- corrected #'s were 653 HP; 630 Ft.Lb. We just switched to the TF intake upon engine install. What a nice piece! It's about 6# lighter, 1" lower and the ports are spot on with the gasket and heads (gasket matched intake).
We did add a 1" carb spacer, so we'll see what the results are at the track and will post them here in a week.
