I used a stock tin valley pan with gaskets glued to each side. [/quote]for what its worth, I just ordered the hughes two piece from mancini for $62.00 figured it was worth a try. shruggy [/quote]
I am curious how this works out . Keep us informed
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm
Power by Tex's Automotive
