I think these springs are around 750 lbs over the nose. They were 290 on the seat and 636 lbs/inch so math works out to 752 lbs. A little stiffer than what it said on the box for whatever reason. I'm seeing about 0.030 deflection for some of the rocker arms but the T&D design appears to be pretty stiff.
